68 W200 front drum/bearing assembly
spesce
City: North Bend
Post by spesce »
1968 W200 100% original with 34,400 miles completely restored EXCEPT the front axle.....and wanted to drive for the memorial weekend. :shame
I was running the 37"s on the truck and hit a large bump at 60mph on the highway and then had a funny pull. :pale I drove home about 5 miles and everything seemed okay. I went for another drive and took a right, went a mile and then took a let on a main road. I heard a pow and hit the brakes, but knew the brakes were done. I turned on another side street and stopped the truck. The right front brake drum had brake fluid draining out. Luckily being in a residential neighborhood, I made it home mostly with going slow and used the emergency brake a few times.
I knew I had three, not so seated studs but torqued the nuts on the wheel. I seemed that I had broken a stud and the stud fell into brake area and broke the wheel cylinder in half.....I knew this drum was suspect, but not that easily. Now with the questions....
-I have purchased brake drums from NAPA and appear totally exact drum, but they do not come with the bearing part....What is this part called?
-Where can I purchase a whole brake drum assembly with bearings or just the inner part?
- The number on the inner wheel part that holds the wheel studs and appears to welded or attached to the brake drum is "86710 L"
- I have the manual, but this part is never shown good so any information helps.
I have pictures that I will post shortly once they make send from my phone.
Steve
North Bend, WA
68 W200 Crewcab
45 Dodge Dump Truck
66 Ocelot Corvair powered Dune Buggy
powerwagon54
City: Washougal
Re: 68 W200 front drum/bearing assembly
Post by powerwagon54 »
pm sent
RussRoth
City: Vancouver, WA
Post by RussRoth »
Hub and drum from a later 44 Dodge axle fits as I have a '72 on mine. The inner bearing is the same actual bearing if IIRC but the inner race is different. Don't ask how I nearly found that one out! :pale :pale BTW, 37's are huge tires for a 44 series axle.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
RoukoSadra
City: Hawk Springs
State: WY
Post by RoukoSadra »
is this the same on a 66 w200 PW?
RoukoSadra wrote:is this the same on a 66 w200 PW?
The '66 & '68 W200 front hub/drum assemblies are the same.
John :study
RoukoSadra
City: Hawk Springs
State: WY
John :study
Thanks!
digdoug
Post by digdoug »
spesce,
Type " swedged " into the the search box at the top right of this page.
91w350 CTD
93w250 CTD
