shoulder belts?
shoulder belts?
My 1968 Crewcab W200 has threaded locations for shoulder belts in both the front and rear locations. Did these ever have shoulder belts? When did Dodge start including this option?
Steve
North Bend, WA
68 W200 Crewcab
45 Dodge Dump Truck
66 Ocelot Corvair powered Dune Buggy
North Bend, WA
68 W200 Crewcab
45 Dodge Dump Truck
Re: shoulder belts?
The hole turned up in 68.I have never seen a stock shoulder strap in a swepty.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Re: shoulder belts?
Maybe Ma Mopar was anticipating a safety change from the bureaucrats that never came about.
- City: Rio Linda
Re: shoulder belts?
My '68 has no holes for shoulder belts.digdoug wrote:The hole turned up in 68.I have never seen a stock shoulder strap in a swepty.
Re: shoulder belts?
I used the shoulder belt holes in mine (they had little buttons in them) to mount new 3 point belts.
The problem I have is that the hole is pretty high so the belt cuts into my neck a little. I wish I could find a set of belts (now that I've spent a good bit on these from Snappin Turtle) that has a lead length that places the point lower. I plan on trying a child seat adjuster to bring it a little lower..... for now I just have pads on the belts. My old belts were crap. I threw them away as they would not have been safe for resale. They would loosen up as you drive.
- City: Rio Linda
Re: shoulder belts?
I stand corrected...I do have holes with buttons, every time I look up that way I'm amazed that they put a wire coat hook up behind the seat, and mine is still there. That was right around the time that the Government started with the pollution stuff too. I think Ma Mopar anticipated it as they were the last of the Big 3 to put smog pumps and pollution controls in. CA vehicles started getting worse then also. I'd be damned to put shoulder belts back in my Challenger, it took me a couple of days to put a headliner in it, I hate them and I wasn't going to cut holes in it.wally426ci wrote:I used the shoulder belt holes in mine (they had little buttons in them) to mount new 3 point belts.
The problem I have is that the hole is pretty high so the belt cuts into my neck a little. I wish I could find a set of belts (now that I've spent a good bit on these from Snappin Turtle) that has a lead length that places the point lower. I plan on trying a child seat adjuster to bring it a little lower..... for now I just have pads on the belts. My old belts were crap. I threw them away as they would not have been safe for resale. They would loosen up as you drive. :pale
- City: Breslau
Re: shoulder belts?
I found seat belts with an 8" shoulder extension option: https://www.seatbeltplanet.com/seatbelt ... 25/view/63
