Tires on stock 5.5 on 5 on 15
Jim100
City: Kalamazoo/MI
Post by Jim100 »
Does anyone run, or know if will work, BF Goodrich 10.5 X 33 15's on a stock width wheel?
1970 W-100 Stock height.
Thanks jim
Re: Tires on stock 5.5 on 5 on 15
That tire is going to be pinched in at bead and very rounded on tread. Will cause fast wear probably. You probably need a wheel at least 8 inches min width. :thinking
my5thmopar
City: Columbia
Post by my5thmopar »
I'm with DKB on this one. You can look through my build thread. I have 31/10.50/15 on a 7 inch rim.
viewtopic.php?f=34&t=36025
I think the general rule is no more than 1.5 inch over each side. I think 8 would be a better choice. If you were off road or around town you "might" be ok. There are 4wd nuts that run 10.5 on a 5.5 wheel. If you want the big tires, get the correct wheel width when you buy those after market wheels. If you even think of going bigger like a 12.5 you better buy the 10 inch wide wheels.
my5thmopar wrote: on a 7 inch rim.
I was thinking that size may also be OK but the minimum width for sure. :thinking
Jim100
City: Kalamazoo/MI
Post by Jim100 »
Thanks for the help.
What is the tallest tire that will fit on my stock wheels? This is a not very often driven truck.
jim
riffraff
City: Newport Beach
Post by riffraff »
Jim100 wrote:Thanks for the help.
jim
I'm running 275x70 BF Goodrich T/A on 17" x 8" steel wheels, with stock springs. I'm not sure the diameter of my tires, but don't think I would want to try anything larger without a lift. They are pretty close to the front edge of the front fenders. You might look through the below
"Wheels/Rims Pic" thread. Not too many W's, but still worth a look:
viewtopic.php?f=3&t=22340
viewtopic.php?f=3&t=22340&start=40#p265628
Tom
1969 W100 383/435
Jim100
City: Kalamazoo/MI
Post by Jim100 »
Wow that looks good! Did you have those steel wheels built?
riffraff
City: Newport Beach
Post by riffraff »
Jim100 wrote:Wow that looks good! Did you have those steel wheels built?
Thanks!
I did have the wheels built. Could've got nice alloys for less, but I do think white steel wheels "fit" the truck best.
Tom
1969 W100 383/435
JohnB
City: Gainesville
Post by JohnB »
That is a beautiful truck and the wheels are perfect for it. Nice job!
1970 W200
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
