How do I get the drag link off the pitman and or steering arm? I have removed nuts but A special tool? Beating?
Thanks jim
w-100 drag link removal
Re: w-100 drag link removal
Oh. Thanks> But which one? The fork like one?
The pickle fork will work if not concerned about reusing the tie rod ends. The tool will tear the grease seal.
For me its careful and proper use with application to the specific area using the BFH. That's all I ever used in the auto wrecker. And I also used Keith, My long Snap on pry bar under certain spots to aid my BFH.
- City: Rio Linda
Leave the castellated nut on the tie rod end loose if you don't pickle fork it and just use a hammer, so you don't bugger up the threads if you go that route. And when you put them back on use some Never-Seize on the tie rod shaft and it'll make easier the next time you need to take them apart and a use a new cotter pin. Any car parts store should have new grease seals.Jim100 wrote:How do I get the drag link off the pitman and or steering arm? I have removed nuts but A special tool? Beating?
Thanks jim
You name your tools?dodgeboykim wrote: And I also used Keith, My long Snap on pry bar under certain spots to aid my BFH.
That.s the only one I named Keith. Keith was the guy that had worked at the wrecker with us and one day basically told us all to go F off. I found it sitting on the last vehicle he processed after he left. That's why I call it Keith.soopernaut wrote:You name your tools?dodgeboykim wrote: And I also used Keith, My long Snap on pry bar under certain spots to aid my BFH.
