Fargo info
sarookha
City: Alba
Fargo info
Post by sarookha »
From what I can tell, there isn't any official information available on Fargo light truck production. But does anyone know of any other sources of information for '60s era Fargos? How can I tell what is factory stock and what is a later modification, if there is no build sheet and no factory data available?
Thanks! David
Re: Fargo info
VIN should denote if its a FARGO or DODGE and also if it came from CANADA as that is where most would be from. They use the same build platform and options as a DODGE. You can even put FARGO letters into same holes as DODGE.
DukePW
City: Sarnia, ON
Re: Fargo info
Post by DukePW »
Yup,
Just minor differences in Fargo's like the radio, steering wheel (some times), the vin tag is put on with philips screws not rivets, badging and tailgates of course. The production numbers are not published, I had to contact Chrysler Canada to get mine for the year and model
67 Fargo W100 Utiline
52 International L-110
Re: Fargo info
sarookha wrote: How can I tell what is factory stock and what is a later modification, if there is no build sheet and no factory data available?
Thanks! David
It depends on the item(s). Some of it you may not be able to tell. Other things like engine, transmission, axles, wrong year parts, etc., would be easy enough to spot.
