need a w200 front axle assembly
keithpurple
City: lakewood
Post by keithpurple »
Mechanic says it has to go...fried the bearings, and bent in the assembly...what will work for replacement? he's recommending ford f250 76-79..want to keep to dodge if possible..
keith
crusty
City: Yelm
Re: need a w200 front axle assembly
Post by crusty »
I have one...too bad it is in washington.
What a mess.
powerwagoncrazy
City: Hubbard, OR
Post by powerwagoncrazy »
Time to find a different mechanic- the pumpkin on the ford axle isn't even on the correct side!
Direct bolt in and go would be '61-'71 Power Wagons (closed knuckle dana 44).
'72-'74 W200's (open knuckle dana 44) have locking hubs, the same drum brakes and same spring perch width but will need the shock mounts cut off and moved to the front of the axle, and you will need to use the drag link from a '61-'71 Dodge 2 wheel drive truck.
'75-'79 Dodge W200's (unit bearing dana 44) don't have locking hubs- they're junk. Don't bother with them.
'80-'84 W250 Power Ram (open knuckle dana 44) axles fit exactly like the '72-'74, but have disc brakes (i.e. you'll need a different brake proportioning valve)
'75-'93 Heavy spec W200/W250's/W300/W350's (dana 60) are effectively a "heavy duty" version of the '80-'84 axles- locking hubs (or at least the ability to have locking hubs), disc brakes, etc. Again, You will need to use a draglink from a '61-'71 Dodge 2 wheel drive, disc brake proportioning valve, move the shock mounts to the front of the axle, etc. Spring perch width is the same as your original axle.
'67-'87 3/4 ton chevy axles can be made to work, but the spring perches are slightly off, shock mounts need moved, steering will need to be modified, etc. etc.
keithpurple
City: lakewood
thanks powerwagon crazy... much information to get me where i need to go without alot of modifications...let you know
powerwagon54
City: Washougal
Post by powerwagon54 »
pm sent
