Steering Stops
Posted: Mon Jun 09, 2014 2:35 pm
Hi, first post in the 4X4 section :)
Recently bought a 1969 W100, and finally got around to one of the little things that has been bugging me. Namely, a very large turning radius.
The steering stops were wound out pretty far, and when I went to adjust them, I found them tack-welded to the axle (wtf). Got past that, and even without any bolts in, I don't seem to have any rubbing. So, I guess the question is, is there any harm in running the steering at max lock-to-lock? Or at least, until they just rub (assuming new wheels/tires)? Just wondering why the PO felt the need to WELD the adjusters in place. Note, I do have bolts in now, wound in tight against the jam-nuts.
Oh, forgot to mention, closed knuckles.
