Factory 1971 W100 wheels
Yellow71
City: 80031
Post by Yellow71 »
HI guys,
Are the factory steel wheels for a 71 W100 any different than D100?
Seems like the center hole must be bigger for the front hubs?
digdoug
Re: Factory 1971 W100 wheels
Post by digdoug »
That is correct. :Thumbsup
Yellow71
City: 80031
Post by Yellow71 »
Are these the original 71 W100 wheels?
I have 2 of these...if they are right....then I need two more.
These are 5 on 5.5..15 inch diameter.
These have 4.5 inch back spacing.
digdoug
Post by digdoug »
I don't know if Dodge offered flotation tire/wheels on the w100. The trucks I have seen have wheels more like this...
http://www.ebay.com/itm/DODGE-TRUCK-WHE ... 60&vxp=mtr
Yellow71 wrote:HI guys,
I'm guessing you know the bolt pattern is different since you mentioned your wheels are 5 on 5.5 inch.
The wheels in you picture are too wide to be factory Sweptline wheels. Back then trucks came with narrow tires.
CMR70D3
City: Martinsville
Post by CMR70D3 »
Here's the factory 71' W100 wheels on my donor.
Yellow71
City: 80031
Post by Yellow71 »
CMR70D3 wrote:Here's the factory 71' W100 wheels on my donor.
Doesn't look like there are any knobs like other wheels have for the hub cap.
Thanks for the photo.
CMR70D3
City: Martinsville
Post by CMR70D3 »
[/quote]
Doesn't look like there are any knobs like other wheels have for the hub cap.[/quote]
I've only seen 1 picture of hub caps on a W100 70'-71'. It was a full cover that had the hole for the front hub lock-outs, not sure if they were stock or not.
I saw a Willy's Jeep on Craigslist with the wheels shown in the 1st picture. They might be optional Jeep wheels.
Yellow71
City: 80031
Post by Yellow71 »
I've only seen 1 picture of hub caps on a W100 70'-71'. It was a full cover that had the hole for the front hub lock-outs, not sure if they were stock or not.[/quote]
Well, what I meant to say...
You can tell if the wheel is original for Powerwagon, when there are no knobs?....Powerwagon had no need for knobs.
