Gents,
Got myself a 63' W200 PW and would like some help on understanding the shift pattern for the twin sticks. Thanks!
Transfer Case Shift Pattern help needed!
Re: Transfer Case Shift Pattern help needed!
You should have an NP201 in your truck. Shift pattern is really simple: the front lever is your high/low range lever and the rear is 2wd/4wd.
Front:
high
neutral
low
Rear:
2WD
4WD
they should be adjusted so that when you shift into neutral with the front lever it just touches the rear lever and pushes the rear lever into 4wd when you shift to low range.
Front:
high
neutral
low
Rear:
2WD
4WD
- City: Fredericksburg
- State: VA
Is there a factory data plate which shows the shift pattern? something origional? Would love to have one.
- State: VA
Thanks for the link Seff
I've been looking around for a few days now, maybe I can post something in the PW section or Parts needed. I could have sworn I seen one somewhere. Should have saved the pic when I saw it....
Try:dahobs10 wrote:Thanks for the link Seff
http://www.vintagepowerwagons.com
- State: VA
Thanks guys, I think what I saw was from the older M37's. My 63' was a Navy truck at first so I might have came across something while first looking around.
This is what my 65 W300 has
- Attachments
- Photo145.jpg (18.43 KiB) Viewed 2231 times
