Anyone ever seen side step fuel tanks on the cab or uteline bed of a W300? I am committed to relocating the tank from the cab to either the rear under bed area( very limited room )
or possibly something like dual steel step tanks in place of the cab or bed running boards.
Thanks
Side step fuel tanks
Drew
1946 WDX FFPW, rear belt pulley
1963 W300
Gone but not forgotten
1946 WDX Crew Cab
1947 WDX
1953 M-37 360 V-8 disc brakes (Don Evans creation)
1958 W-200 with a 315 hemi and 19.5s
1963 W300
1946 WDX Crew Cab
1947 WDX
- pwadventurer
Re: Side step fuel tanks
These guys make after market tanks.
http://www.aerotanks.com/veh/dodge.htm
Or maybe a used one from a larger vehicle
http://truckpartsinventory.com/index.aspx?val=c8_m10
http://truckpartsinventory.com/info.asp ... val=c8_m13
I was thinking something more like this. Possibly in place of the front running board on the utline bed. One on each side. I have been looking at tanks for the area under the bed behind the rear axle. The W300s don't have much space back there. I would like to get a total of at least 30 gal. Maybe 15 gal side tanks.
Thanks
Thanks
- Attachments
- step tank.jpg (3.71 KiB) Viewed 1370 times
Drew
1963 W300
1946 WDX Crew Cab
1947 WDX
1963 W300
1946 WDX Crew Cab
1947 WDX
That would be a good location for them i think..... Or maybe something in the bed if you have room??
- City: Caldwell
- State: ID
I had the idea to make something similar to the picture of the red one but basically replace the running boards on my D300 with them and to have a flat bottom for clearance but make them polished stainless or polished aluminum and have a step to help with getting into the truck. I think it would be an awesome idea. That with possibly a 12Valve Cummins. It would be like a Mini Rig. I thought it would be an awesome idea. Just a matter of finding something that will work or fabbing something up.
Jeff
Jeff
- jimmy
- City: Spokane
I like the tank/step idea.
Alot of guys are using slip tanks under the tool box in the bed. This would also looks good because you get to keep the factory steps.
Did you every get anywhere on this idea? I have a W300 crew cab that I am doing a Cummins swap and have been thinking of dual saddles. with the measurements I am using I would be around 45gallons/tank. http://www.metaltanks.com/tank-capacity-calculators
This place has about all the parts you need to make your own.
http://www.boydwelding.com/shop/
years ago there were tanks that replaced the running boards on some W-300s in the NW
full legnth about 4" deep at the step and 4 to 6"s wide going up to the bottom of the cab.
never found out who made them and didn't have money to try and get them
