Any one Ever Try to Make a 6X6 Power Wagon
Has any body ever tryed to build a power wagon in to a Tandem Rear Axal,Like a 6X6,so that both axals Drive,like a tractor trailer,where both axals can be locked together for better pulling,for use with gooseneck trailer pulling,I know there are kits that will do this but the rear axal does not drive,most are air ride set ups !I have all the parts to made this work I think ??
Re: Any one Ever Try to Make a 6X6 Power Wagon
Yep here is one for sale: http://www.dodgepowerwagon.com/classifi ... 44wc62.php
Bob in Chicago area built the best one I've seen, powered by a 6BT.
Will
1946 Dodge Power Wagon http://powerwagon.wawii.com/46.html
1949 Dodge Power Wagon http://powerwagon.wawii.com/49.html
1953 Dodge M37 http://m37.wawii.com/
1964 Dodge W500 Fire Truck http://powerwagon.wawii.com/W500.htm
2006 Dodge 3500 Mega Cab http://wawii.com/My3500Megacab/index.htm
Will
I believe Terry [aka PwrWgnDrvr] has a 6x6 Flat Fender Power Wagon too.
hoping it had been done to a 61-71 !!!I was thinking of making one out of a 67 D400 or 67D500 or maybe my old 70 D500 I used to used as my Equipment Truck / Tilt bed with Winch 18 Ft flat bed box !!!caseman wrote:Has any body ever tryed to build a power wagon in to a Tandem Rear Axal,Like a 6X6,so that both axals Drive,like a tractor trailer,where both axals can be locked together for better pulling,for use with gooseneck trailer pulling,I know there are kits that will do this but the rear axal does not drive,most are air ride set ups !I have all the parts to made this work I think ??
- azlaw
- City: Tucson
- State: AZ
There was a WT-500 that had tandem rears from the factory. Some photos located at: http://imageevent.com/moparnorm/bigdodges
HLJ
HLJ
That's the truck Bob Jones built, he did a beautiful job.gp-az wrote:see this.http://www.vintagepowerwagons.com/one-o ... -drive.htm
Will
Will
Taht yellow one is so friggin nice. up here in WA there is a similar one that was built many years ago and is powered by a 392 HEMI. Has a lengthened first series 4 pocket bed.I saw it for sale up in the San Juans a while back.
CAseman, I have a rear frame section with suspension from a 6x6 dodge we parted out. you could use 70s ford van Dana 70 rear axle for the offset side and a centered 70 for the forward rear axle. it is rated at 1.5 tons and in good shape. any interest?
- Trailmaster
- City: Ellicott
I had kind of kicked around an idea along the same lines for a while for a twin screw D300. My idea was offsetting the diffs as mentioned above using a modified NP203 transfer case for an interaxle differential. I never did get around to checking the feasability of modifying a 203 so that both inputs came out the rear, and one would have to figure the driveshaft angles to make sure that the articulation wouldn't overdo the short driveshaft required if you mounted a carrier bearing on the front dif.
I've seen a lot of tag axle setups, but tire wear and driveabilty issues can pop up if you aren't running loaded a good portion of the time.
75 Duster 225/904/PS
- Butch Romig
- City: garnett ks
somewhere i seen a truck that had two rear axles,one was driven by a driveshaft,the rear one was ran by some sort of track or belt that ran from front to back axle,but it wasnt a track like a dozer the wheels were free of any tracks
- 65junkie
- City: Pipe Creek
I have always wanted to make one only with dually axels in the rear, I think that will be too cool!
Tyler C.
64 d-100 utiline
(2)73 dodge club cab aventurer's
69 charger
01 dodge 2500 4x4 diesel
64 d-100 utiline
69 charger
- Boons
- City: Innisfail
http://www.dodgepowerwagon.com/classifi ... 809-46.php
Nice one for not a bad price.
1989 Ramcharger LE 318/727 2wd (For Sale)
"FUBAR"1971 Fargo D-100 LA 318/727 Auto
"SNAFU"1968 Fargo W-200 POWERWAGON 383/Np 435 4 speed/Np 202 T-case.Dana 60 rear Dana 44 front
