NP205 rebuild kits
- marklein
- City: Red Deer
Re: NP205 rebuild kits
Do you have a factory service manual? It is in there, with a decent pic. Interestingly enough, the fsm shows the brake on the back, but I'd bet the manual never got changed from earlier. If you want to pm me an email address, I'll take pics of the manual pages and send them to you.
By, "the output gear," I assume you mean the main driveshaft gear. If you have a photo, I'd like to see it.
- jwing68
- City: Lethbridge,Alberta
You are welcome Mark I know how difficult it can be locating some of these pieces, unfortunately I have not had any luck sourcing parts in the parts wanted section of this forum either.marklein wrote: ↑Mon Nov 11, 2019 11:34 amFrom what I own and have seen, the last year for the np201 ebrake was 65. I have a 65, it has the ebrake, I just bought a 66, it doesn't, and neither does my 67. A 201 is similar to a 205, but as mentioned earlier, there are more tapered rollers in a 201. I rebuilt mine, if you have access to a press, it will help. Also, the output gear has torsional springs that will need to be dealt with. Take pictures as you tear it down, I will check again to see if I have a manual that covers it. I have worked in the trans industry for 30 years, I had built most tcases there was, but untill I did my own, I had not seen a 201. It might be difficult to find someone who has done one. I will help if I can, pm me if you need help. I just finally got the last pieces I need to put the ebrake on the back of mine, thanks Jack.
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
- marklein
- City: Red Deer
the springs can break and then can go through the gears chipping them.
this is after welding. There is a thread about here about it somewhere. I checked to see if my suppliers can get a bearing and seal kit. I can get one, but it comes only with the big bearings, not the rollers.-
Geezus, u are responding to a TEN YEAR OLD post! Some of the posters on this thread have even passed on!marklein wrote: ↑Mon Nov 11, 2019 11:34 amFrom what I own and have seen, the last year for the np201 ebrake was 65. I have a 65, it has the ebrake, I just bought a 66, it doesn't, and neither does my 67. A 201 is similar to a 205, but as mentioned earlier, there are more tapered rollers in a 201. I rebuilt mine, if you have access to a press, it will help. Also, the output gear has torsional springs that will need to be dealt with. Take pictures as you tear it down, I will check again to see if I have a manual that covers it. I have worked in the trans industry for 30 years, I had built most tcases there was, but untill I did my own, I had not seen a 201. It might be difficult to find someone who has done one. I will help if I can, pm me if you need help. I just finally got the last pieces I need to put the ebrake on the back of mine, thanks Jack.
Terry,PwrWgnDrvr wrote: ↑Tue Nov 12, 2019 11:06 pmSome of the posters on this thread have even passed on!
Who passed on?
MoparNorm
I missed his post on Pg.1.
And, I miss Norm too.
- marklein
- City: Red Deer
I know it's old info, but it is sometimes easier and faster to post a pic than it is for someone to search for hours for info.
I have two '68 NP201 cases without the brake. I also have a 205 on another truck.
- marklein
- City: Red Deer
Place called Cobra Transmission, lists a full rebuild kit for a 201. Decently priced too.
