W100 with factory spicer 60?
- 65alive
- City: Joseph City, AZ
- State: AZ
Hey guys,
I picked up a parts truck, I haven't run the #'s yet but it looks like a '64/early'65 W-100. It's a short box with 8 lug axles and looks like it has been "customized" 1/2 a dozen time using the bailing wire approach. I was out looking at it the other day and noticed something unusual. The door tag lists it as coming from the factory as a W-100 with the short bed wheel base and a spicer 60 rear axle (looks like a 44 up front). I almost fell over. I had always assumed that someone had swapped axles with a W-200. I have never seen a 1/2 ton truck with a stock spicer 60, let alone a short bed with that option. If anyone has ever seen this I'd be interested to know about it.
Thanks
Thanks
- RussRoth
- City: Vancouver, WA
Re: W100 with factory spicer 60?
That was normal through '68.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
- PowerMan
- City: Auburn
Our W100's (1962 and 1965) have the Dana 44 front and Dana/Spicer 60 rear with 4.10 gears.
Power Man
Power Man
- 65alive
- State: AZ
Thanks for the info guys, I'm more into the 2 wheel sweplines, so I'm not real familiar with the 4x4 stuff.
Mopar or NOCar
1965 D100 SWB IFS 383HP
1993 Dakota 5.7 Hemi
1965 D100 LWB Poly auto (my first swepty)
1995 Jeep Grand Cher.
Joseph City AZ
Joseph City AZ
I have a '68 W100. Mine has
a 3.54:1 gear ratio John
Since nobody specifically mentioned it I will. All 61-68 W100s were shortbeds with 8 lug axles. All the W200 regular cab trucks were longbeds with the same axles.
John, my red truck looks to have had the same type plow as your W100. Does yours have a cable controlled Mity electric/hydraulic pump? what brand blade is it?
Is that true? You couldn't get a 61-68 W100 long bed? You could get a D100 long bed for sure.soopernaut wrote:Since nobody specifically mentioned it I will. All 61-68 W100s were shortbeds with 8 lug axles. All the W200 regular cab trucks were longbeds with the same axles.
1969 Adventurer W100
Correct. The W100 from '61-'68 was 114" in wheelbase and had the DANA 60 rear and DANA 44 front.Russ wrote:Is that true? You couldn't get a 61-68 W100 long bed? You could get a D100 long bed for sure.soopernaut wrote:Since nobody specifically mentioned it I will. All 61-68 W100s were shortbeds with 8 lug axles. All the W200 regular cab trucks were longbeds with the same axles.
I am not sure whether or not the large knuckle 44 front was an option. .... I'd only be guessing.
Doug,digdoug wrote:John, my red truck looks to have had the same type plow as your W100. Does yours have a cable controlled Mity electric/hydraulic pump? what brand blade is it?
I believe my plow is a Western. The hydraulics are someone's home made contraption... lever operated.
