67 power wagon
Re: 67 power wagon
The cab itself is almost identicle between 67 and 68(with exception of the dash and door interiors,and shoulder strap anchor on the 68).Lots of little differences between 67 and 69-71.
Re: 67 power wagon
i guess what i was wondering is, i have a 70 powerwagon and i need a cab for it because mine is rotten, would a 67 bolt on fine and is the outer appearance the same, interior stuff is no big deal to me, thanks
Re: 67 power wagon
No, I would look for a 69-71 cab,unless you wish to do many mods.You can do a search,as this topic has been discussed in length,unless someone wants to give you the whole story.
Re: 67 power wagon
Well the outer appearance is exactly the same but it would involve some work do to different style pedals. I'm assuming you have a manual transmission. Swapping from the new style clutch setup to the old one takes a lot of modifications. There are other differences that might require modifications too.
