Hello all,
Just bought a 1966 W200 from a friend. Has 86,650 original miles and is in stock condition. Has a utility box, going to remove it and build a flat-bed for my use. I have a lot of changes to make to it, cannot leave things like the factory made them. I believe it has a 318 poly, how do I tell? Going to upgrade to Pertronix ignition, dual pipes and Summit mufflers, plug wires, rebuild 2-barrel (maybe later swap to 4-barrel)
I am going to have a lot of questions to ask. Where can I find specs on this engine-timing, valve adjustments, normal tuning specs?
66 W200
Re: 66 W200
http://www.sweptline.org/modules.php?na ... light=polyleo1287 wrote:I believe it has a 318 poly, how do I tell?
