I have a newly acquired w-200 four wheel drive. Is it normal to experience difficult steering when it is in 4 wheel drive high...it takes both arms to make a wide turn almost to the point of impossible. Is their any suggestions with replacement parts to make it easier to steer such as new lock out hubs, etc?
Please reply!
steering problem with my 1969 w200
steering problem with w-200
No, I have no modifications. The truck is very original with no mods. whatsoever.
- RussRoth
- City: Vancouver, WA
Bryan,
Are having difficulty off road with your steering? Or is it doing this on the pavement? If this is on the pavement your steering will be difficult and the rig will jump and buck while going through all manner of contortions. Not really recommended.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
If you have wide tires the steering is going to be hard, at least it was on both my 67 and 69 W100s. There's not much you can do about it other than add power steering. There's several posts here on the forum with pictures of how some others have done it. Like Russ already said, you should never drive it in four wheel drive on pavement.
1969 Adventurer W100
- Ruckus
- City: Stevensville, Montana
Re: steering problem with my 1969 w200
Yes, narrow tires are like adding power steering, and you might check for a front locker which would make steering in 4x4 nearly impossible.
78 W200 crewcab, 68 W200, 59 Willys Wagon, 52 Ford F5 Cabover
