8 lug dana 44-35 closed knuckle front end
Postby pitbull6996 » Sun Apr 15, 2007 6:18 pm
need help to figure out ...does anyone have pic's...
i have aquired a 8 lug dana 44 closed knuckle with 4.10 gears that are dated 9 26 62 on ring gear it has large knuckles ..my best guess is it might be 300 series...trying to find replacement parts ie spindle and wheel brg nuts, drag link w/tie rods, spring mountpads (diff. side critickle as it has a odd shape to the bottom of the axle)both sides prefered...wanting to mount under front of 66 camper special that is converted 4 wheeldrive w/6in skyjacker lift....i have viewed other 44 fronts all have had small knuckles thus adding to my confusion. thanks for any help :study :banghead :censored
ps.my spindle's are held in place by 11 bolts with a gap at 6oclock position(no hole)
pitbull6996
Postby digdoug » Sun Apr 15, 2007 10:22 pm
:welcome What you have is the HD-44-f. It was a option in the W200.It is rated as a 3500lb axel,but all the trucks I have seen them in(I have three) say 3000lb on the data plate.The spindle is the same as the 3000lb axle except it has 5 more holes.Spring mount pads,and draglink are the same too.Look below in this section for a draglink sourse.
http://www.sweptline.org/modules.php?na ... ic&t=10824
digdoug
Postby Tufftruck » Sun Apr 15, 2007 10:43 pm
pitbull66996:
I have a complete front differential from a 69-71 W-200. If you want it come and get it. It's in Clovis, Calif. near Fresno.
Tufftruck
Postby PwrWgnWalt » Sat Apr 21, 2007 7:35 pm
Vintage Power Wagons has the "Big-Knuckle" stuff you're looking for. Look in their on-line catalog for the 3500# axle...
PwrWgnWalt :usa
PwrWgnWalt
City: Shepherd
State: MT
Return to POWERWAGON 4X4 DISCUSSION
Who is online
Users browsing this forum: No registered users and 2 guests
