axle shaft movement
axle shaft movement
Postby Jim100 » Tue Nov 14, 2017 5:39 am
With the dial hub lockers removed from a dana 44 how much should the axle shaft be able to be moved up and down. Trying to determine the state of the spindle bearings.
jim
Jim100
City: Kalamazoo/MI
Re: axle shaft movement
Postby wyota884 » Tue Nov 14, 2017 9:17 am
The axle shaft itself will move a fair amount, the only thing locating the shaft is a bushing # 2-03-4 in the diagram. It is just a bushing, not a bearing, so there will be wear allowing more play. The lock out hub will actually help locate the shaft as well. But, movement of the shaft does not have anything to do with play in the spindle bearings that support the hub. That is adjusted by the pre load on the spindle bearing nuts #22-06-9. Hope this answers your question.
1965 W200
2006 2500 Cummins
1996 FZJ80 Land Cruiser
wyota884
City: CASPER
State: WY
Postby Jim100 » Tue Nov 14, 2017 12:33 pm
It does. My axle is a 1980 open knuckle but seems like the same would apply. Mine does have spindle roller bearing so maybe I better just take it apart more.
Jim100
City: Kalamazoo/MI
Return to POWERWAGON 4X4 DISCUSSION
Who is online
Users browsing this forum: No registered users and 1 guest
