Page 3 of 3
Re: What do you do with your sweptline today?
Posted: Mon Nov 20, 2023 1:29 pm
by BigBlockTrucks
The plan is to roll some new bearings in it and run it.
I have seen this once before. It was on a Chevy engine with a cast crank and the thrust surface on the crank was worn also. That one went in the scrap pile.
This time the crank still looks good. Just a worn bearing.
Posted: Mon Nov 20, 2023 3:36 pm
by PwrWgnDrvr
BigBlockTrucks wrote:
Mon Nov 20, 2023 1:12 pm
PwrWgnDrvr wrote:
Mon Nov 20, 2023 11:18 am
Wouldn't the fan spinning on the front keep the crank full forward against the thrust bearing?
I wouldn’t think so the fan is on the water pump.
Ya, needed more coffee... :banghead
Posted: Mon Nov 20, 2023 9:34 pm
by nutz
ha fan...good one
would think you can find thicker thrust bearing as long as crank isn't worn
thinking it was out of a manual trans ..only time i ever seen thrust bearing ware
Posted: Wed Nov 29, 2023 9:20 pm
by thehemikid
Apologize for leaving it outside for a few days so I could do some work on the skid.
Posted: Tue Dec 05, 2023 4:42 pm
by Wildergarten
Drove the Green Truck down the hill into Silicon Valley to deliver a pallet of a 69 W200 driveline components to Old Dominion Freight. Stopped at the Hospital for a pacemaker check. Got a burger for breakfast (the first I've had in a couple of years). Stopped at A&M Motor Parts. Spent a half hour at the Post Office.
The entire time I never locked it. Seeing as the truck has this special security system otherwise known as a "manual transmission."
Posted: Tue Dec 05, 2023 10:01 pm
by BigBlockTrucks
A manual choke is almost the same deturant if the engine is cold. The battery will die before they could make it start.
Posted: Tue Dec 05, 2023 11:29 pm
by Wildergarten
Unfortunately, the Edelbrock thermoquad carburetor accelerator pump bore on The Green Truck is so corroded it can't squirt, so I have to keep a can of ether in the cab or I can't start it. Of course, that presupposes that said malefactor wouldn't think the ether is for vaping ether instead of starting the truck. :joker
Posted: Mon Dec 11, 2023 1:40 am
by Dale
Thanks everyone for the help. Take care!
Posted: Mon Dec 11, 2023 11:11 am
by JohnB
Checked the fuel tank sending unit and ended up replacing the brass float. I was getting inaccurate readings and thought maybe the variable resistor was bad but found the float with a crack and filled with gas. Reads correctly now. I dug out an NOS sending unit just in case but wasn't needed. That's it, no major work done.
Posted: Tue Dec 12, 2023 6:00 pm
by Frankenline
I had my flywheel resurfaced, ordered my ring gear, bought some bolts.
Posted: Tue Dec 12, 2023 9:48 pm
by Wildergarten
The Green Truck moved four 16' cattle panels and a gate for a wild pig trap down to the house. Balanced them hanging over the cab. I'll be using the panels as reinforcing wire in concrete slabs I hope to pour this month.
Posted: Wed Dec 13, 2023 1:36 pm
by Dale
Great news, got my parts catalog!
Posted: Wed Dec 13, 2023 3:18 pm
by PwrWgnDrvr
Nothing but the FSM.
Posted: Sun Dec 17, 2023 9:52 pm
by Dale
Merry Christmas and happy new year everyone!
Posted: Sun Dec 17, 2023 10:55 pm
by PwrWgnDrvr
No gaskets used there.
