Fuel sending unit wiring
- City: Wichita falls
Hello can anyone send me wiring picture of the sending unit and how it hooks up thanks
Re: Fuel sending unit wiring
Pull the seat forward; it's on top of the tank. There's an insulated stud on one side that gets a 90° connector boot with a coil spring inside attached to a wire across the top that is in a probably rotting sheath. The sender is installed with a locking ring one can rotate with a small hammer and screwdriver. Once it come out, you'll probably need a new gasket and that's not so easy. I don't know the original thickness.Sweptybrown wrote: ↑Mon May 04, 2020 9:30 amHello can anyone send me wiring picture of the sending unit and how it hooks up thanks
Hello does the wire with the boot is it blue with like a little motor i guess clicks on the sending unit with another blue wire on it
- pwadventurer
The sending unit wiring in your truck should look similar to the attached photo. It's a 1 wire hookem up.
