Hello from Germany,
finally I managed to buy a 1965 Shortbed Sweptline. I hope to receive it before Xmas. I had already several later Lifestyle Pickups and this
is my first Sweptline. There is a good amount of people over here which likes old american irons and beside the Sweptline I have a 64 Dodge 440,
recently sold my 71 Sportfury and had years before a 69 Roadrunner, 68 Superbee, 72 New Yorker, 68 Fury Convertible and so on...you got it
Mopar only
My very first question: with the changes of the year 1965 did they switch to the pie pan grill AND the modern bed at one time?
Or otherwise a 65 Pie Pan grilled sweptline with a early bed is a Heinz?
Thx
Peer
New User from Germany
Re: New User from Germany
Welcome to the site.Peero wrote:Hello from Germany,
Mopar only
Thx
Peer
In mid '65, the grille was changed from the 4 headlight to the 2 headlight [pie plate] style.
Also, the early single wall round tail light Sweptline bed was replaced by the later double
wall bed with the oval tail lights. You can use either style short Sweptline [or Utiline] bed
as they are all designed for a 114" wheel base. If a "Heinz" means not original, you would
be correct with regards to the pie plate front in combination with an early style bed.
OK than one of none made....
Welcome from Germany to Germany - which area you're from?
I am mopar only, as well (both '69 Charger and A100) - we might have had contact at the mopar-forum.de? Or maybe you'll also try dodge-trucks.de - lots of knowledgeable people over there as well as here
I guess so! Whats your name at http://www.mopar-forum.eu/ ? Mine is ToniMontana6969 wrote:Welcome from Germany to Germany - which area you're from?
I'm the troll nicknamed 69.
Your nick is known to me ;)
