Original Radio
Original Radio
I have an original Chrysler solid state radio from a 69 dodge I'm using for parts. I'm not looking to sell it at this time but I am a teenager trying to restore a 383 4 speed survivor. I was just wondering what it was worth, and it does work.
Re: Original Radio
Probably somewhere between $15-$30 depending on condition? This
has 48+ year old capacitors, resistors, etc. in it.... so there's no telling when
it'll give up the ghost.
- 64D100Poly
- City: Vancouver
Re: Original Radio
I replaced every electrolytic capacitor in mine, I also soldered in an aux cord into the volume pot so I plug my phone in and it throws the phones audio signal in before the AM radio signal, unplug it and its just like factory.
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
Re: Original Radio
Great idea! What kind of phone, where did you get a speaker output from it (is it the round jack port on the top of an Android?), and how did you attenuate the signal to the correct level?64D100Poly wrote: ↑Fri Feb 11, 2022 2:43 pmI replaced every electrolytic capacitor in mine, I also soldered in an aux cord into the volume pot so I plug my phone in and it throws the phones audio signal in before the AM radio signal, unplug it and its just like factory.
- 64D100Poly
- City: Vancouver
Re: Original Radio
Wildergarten wrote: ↑Fri Feb 11, 2022 5:09 pmGreat idea! What kind of phone, where did you get a speaker output from it (is it the round jack port on the top of an Android?), and how did you attenuate the signal to the correct level?64D100Poly wrote: ↑Fri Feb 11, 2022 2:43 pmI replaced every electrolytic capacitor in mine, I also soldered in an aux cord into the volume pot so I plug my phone in and it throws the phones audio signal in before the AM radio signal, unplug it and its just like factory.
This is what I followed: https://www.instructables.com/Adding-Au ... r-to-an-O/
Unfortunately as of recent water dripped in from my windshield through the speaker grille and smoked my radio, when it WAS working I got a Bluetooth to AUX (AUX being the round port on your phone) adapter and synced it to my phone wirelessly, I could even run phone calls through it! The thing I really like is your in no way harming or modding the radio in a way that can’t be reversed to fully original, and because your throwin the signal in over the AM signal it’s amplifying and running the audio through all its original components and giving that iconic vintage radio “warm” type of sound. The radio demonstrated by chance happens to be the same radio dodge used from 61 to I believe 67/68 (made by Bendix) and all they did for Fords was change the faceplate.
For adjusting the level you adjust the volume on your phone like if you had headphones plugged in, I set mine half way so it don’t sound to thin/over amplified, then you can use you actual radio knob for volume, the install seems a little technical but if I can do it anybody can!
Best of luck-LB
OO\===/OO
OO\===/OO
Re: Original Radio
I have 5 1970 models here, cars and the truck.
Two of them have higher end radios, one Am / FM and on AM - 8-track.
To me, the radios are just extra weight, all I want to hear is the engine.
Re: Original Radio
Many Thanks!64D100Poly wrote: ↑Fri Feb 11, 2022 7:22 pmThis is what I followed: https://www.instructables.com/Adding-Au ... r-to-an-O/
....but if I can do it anybody can!
M
