Date of Manufacture
- 1965DodgeD100Dave
- City: North Bend
- State: NE
Date of Manufacture
where would the date of manufacture be on my early 65 Dodge D100?
- surfnuke9
- City: Churchton
Re: Date of Manufacture
Probably not the same, but on my 71 it is on between the drivers door hinges on the cab pillar. A decal.
if you decode the vin it might tell you.
http://www.sweptline.org/SweptlineRegistry/
try that with your vin, it might tell you.
- 1965DodgeD100Dave
- City: North Bend
- State: NE
it says my vin is invalidSeff wrote:if you decode the vin it might tell you.
if you have a Factory Service manual, it should have a way to decode your vin.
1965DodgeD100Dave wrote:it says my vin is invalidSeff wrote:if you decode the vin it might tell you.
Either you entered it incorrectly or you have a misstamped VIN plate. The other possibility is that you have a Canadian VIN. The VIN won't give you the exact date of manufacture either but will give you a sequence number. Some of the later trucks had a sticker in the door opening with the month and year of manufacture.
- MrMopar
- City: Lompoc
The other thing that can happen is for some reason the DMV needed to issue a new VIN, these typicaly have the agency name on them.soopernaut wrote:Either you entered it incorrectly or you have a misstamped VIN plate. The other possibility is that you have a Canadian VIN. The VIN won't give you the exact date of manufacture either but will give you a sequence number. Some of the later trucks had a sticker in the door opening with the month and year of manufacture.1965DodgeD100Dave wrote:it says my vin is invalidSeff wrote:if you decode the vin it might tell you.
Alan
Tried to decode my 66 D0dge W100 VIN and it came up invalid. Yes its a Canadian Dodge truck. E-mailed the registry Pics and stuff for help and to register my truck I hope.
- CSS-Registry
- Administrator
- City: Gainesville, Florida
on the earlier trucks the VIN does not give you the exact date of manufacture - just the year in which the VIN fell into.
the only place you'll find the exact date is the build sheet - mine was scheduled on 7/10
Ben
Ben
Wow. That is the first build sheet that I've seen for a truck. Cool!
- 1965DodgeD100Dave
- City: North Bend
- State: NE
i found my build Sheet in the back of my trucks seat. it was built on 4/23/65 :Dwally426ci wrote:Wow. That is the first build sheet that I've seen for a truck. Cool!
