71 dodge d-100
71 dodge d-100
well just baught a 71 have not got it home yet monday i will though. its pretty clean needs a little work. will have to find some mirrors,and get the wipers to work and fix i fender brace on right side.other than that it just needs cleaned up. 318 727 trany. only has 80,000 miles on it. i am thrilled to death with it
john to the site , sounds like you have a good truck , on your wipers , unless you already know whats wrong with them , start with checking the fuse , or if you can here the motor working ,or the wiper arms can be loose or strip out easy fix , if you need any parts just post under parts wanted here on the site Good luck on her & come back soon & just kick you shoes off & vist
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
- wideblock
- City: las cruces nm
- State: NM
hey dave, in all them parts you and chris took, theres a set of 70-71 wiper pivots i found on my 66 wipers, all it needed was a little grounding help. ran a jumper wier from one of the wiper motor bolts to a good clean surface under the dash. it isnt a permanent fix, but it worked for 2 years. welcome to the board john. check with napa, they sell new wiper motors for around $75 if you need one. if its the switch, good luck, i had to buy one from the salvage yard. no one around here sells any new ones.
- wideblock
- State: NM
assuming its a half ton, the pattern is 5 on 4.5 bolt circle. this is shared with ford cars and small trucks, dodge cars, some jeeps, and toyota 5 lug trucks. whatever you get, make sure the back spacing is no more then 3.5 inches or you will rub the steering arm in a hard left. i had 15x8 amercan racing mags on mine with 31x10.5x15's on all four corners. this is the biggest tire you will get on the front of a half ton without modifying the fenders. the back will hold up to a 33x12.5x15. be carefull on some mags as well, one set i tryed had the center too thick for the stud length i had, and finding left hand tread mag wheel nuts is nearly impossible.
