If you are in the NW and see this pickup, or a 4 door that looks very simular, check out the steering. http://www.sublimityharvestfest.com/ima ... /546-6.jpg
Dan said he would send or post the details of how he put the newer steering box in without welding.
the above has tilt also, it's his sons pickup
a cheaper method to install power steering that we can do
steering
They are in the Grants Pass - Roseburg area
he is goiong to try and get pictures if he can get hold of a digital camera
the basic is to weld up a bracked to bolt the steering box to
on the front of the frame
Hi,
I know that it a steering box out of a newer pickup
not sure if it was a D or W or even it that matters
I just glanced at it and it looked good
with no welding on the frame.
when he sends the info you will see that he did a sweet job
